Engine overhaul kits
6030tom
11-17-2005 14:57:33
Have any of you guys purchased one of the rebuild kits (for new generation 6 cyl)off of this website and what do you think?
Mother Deere wants $100 a sleeve and $200 a piston = $1800. The kit on here is just over $2200.
Sure would appreciate you thoughts
Thanks
G/MAN
11-17-2005 15:21:01
 Re: Engine overhaul kits in reply to 6030tom, 11-17-2005 14:57:33
I can't speak to the quality of the kits sold here, but I've seen plenty of will-fit kits and parts, and haven't been particularly impressed. Took one 4430 apart that had been will-fit kitted, and found that the main bearings were different than what Deere uses in their kits. They had a full groove in both shells, while Deere uses a solid shell in the cap and a grooved shell in the block. Grooved cap shell = less bearing surface area = heavier loads applied to the existing area = faster wear. If it were a lightly-used "play" tractor, I'd still maybe consider will-fit parts. For a field tractor getting serious use and lots of hours, OEM parts every time. BTW, what kit are you pricing there? For a 6030?
6030tom
11-17-2005 20:14:27
 Re: Engine overhaul kits in reply to G/MAN, 11-17-2005 15:21:01
yep
G/MAN
11-18-2005 07:32:43
 Re: Engine overhaul kits in reply to 6030tom, 11-17-2005 20:14:27
No kit available from Deere for the 6030 apparently. By the time you buy a gasket kit and so forth, you'll probably have a bunch more money in the Deere parts. Just depends on your budget. Labor is the highest part of an engine overhaul, so if you do it yourself, you have more money to spend on parts within the same budget. I'm a JD technician, so obviously I'm biased toward Deere parts as that's all we install normally, and have had no problems with them. As I said, I've seen inconsistencies in other kits.
Glen in TX
11-18-2005 11:30:35
 Re: Engine overhaul kits in reply to G/MAN, 11-18-2005 07:32:43
Yep never has been a kit for 6030 I don't think? They told us that when overhauling ours years ago. Then the dealer shop said no warranty unless they used all JD parts and it ended up costing way too much when they were done. Still had some leaks and they didn't fix them and I had to do it myself. And some dealers wonder why they lost business? A 619 conversion or trading tractors would have been the way go I realized later.
JD man in SD
11-17-2005 16:22:10
I have been overhauling JDs for 40 years the last 10 i have used Reliance kits you can get them as a in frame kit or major out of frame .in ten years i never have had any problums most JD kits come with new rod bolts FM brgs all gaskets sleeves, pistons, rings, pins, pin locks, pin bushings,sleeve seals.crank seals cam bushings are in major set call Howard Enterprlses 1 800 342 2545 for local dealer
