Mark & Jak are both right. What you describe sounds like a Delco distributor so I'll describe that. If you remove the spring clip retained cover from the center of the flywheel cover, there should be a mark at the bottom of the hole that looks much like a chisel mark straight down from the center of the crankshaft. One of the flywheel's webs should have a small (Clover seed sized) punch mark on it that aligns with this "chisel" mark when the left piston is at 0*TDC. Verify you're at 0*TDC COMPRESSION (valves closed) now. If you remove the distributor at this point, the drive coupling slot on the right end of the governor shaft should be horizontal or very close to it. If not horizontal, the governor shaft may be out of time with the camshaft, the camshaft may be out of time with the crankshaft or maybe even some of both. If it is not horizontal post back for more information. If the slot IS horizontal as it should be, put the distributor back on with the wire towers of the distributor cap facing forward & the rotor pointing to the top tower's contact in the cap which probably is straight up. With the mount bolts snug but not yet tight, roll the distributor housing counter clockwise until the points are fully open on a high point of the cam and set the proper point gap. Roll the distributor clockwise until the points are closed. Pull the coil wire out of the cap & hold the distributor end of the wire 1/4 inch from the governor housing. Turn the ignition switch on & slowly rotate the distributor counter clockwise until the coil sparks. Tighten the mount bolts, put the left plug wire in the top hole, the right in the bottom & it should start and run well. Precision here helps so don't get wicked rotating. Before I start the tractor I usually at this point put the gear shift into neutral, engage the clutch & roll the belt pulley backwards until the points are closed then roll the engine carefully and slowly forward until it sparks. Then I go look at the timing marks. You do not want it to spark before zero degrees! It's hard on the starter & hard on you if you're hand cranking. A little error here can make a big difference. Post back with your findings and good luck.
