41 B manifold problem
davidz
11-17-2005 09:11:40
Just got me my first JD, 1941 B. Manifold needs to be replaced, more than half has rotten away, but the bolts have not nuts, and the bolts seem to be "frozen" to the remaining manifold parts.
Question is, are the bolts tighten on the manifold semipermenent so that nuts are the only thing that come off when replacing manifold, or does the whole bolt come off? In my case I will have to take off what is remaining of the bolts since they are pretty rotten. I just need to know how it originally worked so that I have an idea how to approach the problem.
Also, can I use heat around that area of the engine since I have a feeling the bolts will break when I try to take them off??
Any help to this first timer will be greatly appreciated. Davidz
DickD
11-18-2005 02:39:43
 Re: 41 B manifold problem in reply to davidz, 11-17-2005 09:11:40
David; Something else I forgot to tell you and I didn't look in the I-T manual to see if they mention it, but you need to check the head with a straight edge to make sure it isn't a little warped where the manifold bolts to the head surface. Any machine shop can plane it a little to give a good match to your new manifold.
Walt in Jaxn Tn.
11-17-2005 18:38:16
Are the bolts hardened, do they have a gold tint to them? I've seen some around here that look like that. Someone will come on here and tell you to apply heat to the manifold and the head where the bolts screw in and try to work them out. My "B" parts book printed in March 1960 only shows studs with nuts holding that manifold on, and it only shows a hot manifold where it shows hot and cold manifolds for tractors built after 201000, also there is a break in stud lengths around 183972 (don't know why). Since it's got bolts instead of studs, I'd say the manifold has been off sometime in the past, mabey to replace the gasket or mabey to change the hot manifold to a cold manifold. --Walt--
DickD
11-17-2005 18:19:13
David; Welcome to the land of skinned knuckles, and dirty fingernails. Very probably, if your manifold has been on for quite a while, the bolts inside the manifold that have been subject to the severe heat, and exhaust, have deteriorated to 1/3 the normal size, and when you put a wrench on them they will break the rest of the way in two.
Sometimes if you tap on them several times and soak them with rust inhibiter and use some heat, and if the Lord is willin, some of them will screw out. The rest you will have to drill and tap CAREFULLY! Good Luck. If I can be of any help, email me. DickD
