Even though we sold 820s, 830s, 1020s, and 300s new - I don't recall all the options and differences. You ARE better off with a 1020 or 300 as far as parts availabilty or interchangibility goes. All tractors with closed-center hydraulic sytems use two pumps - a feed pump (in transmission) and a high pressure (engine driven) pump. This much I can tell you: There was a specific hydraulic pump used for 820s, 830s, and early 2040s with manual steering. I think it was an aluminum gear-pump driven by the engine. Pump part #s AT-28460 and AT-24940. 820s, 830s, and 2040s WITH power-steering used a Bosch hydraulic pump with an open-center hydraulic system. Pump part number AR55346. 1020 AG. and 300 Industrial is almost identical to the 820 and 830 with added options. They came with a closed-center hydraulic system with either a key-driven shaft or a splined shaft. The key-driven pumps were used on 1020, 1520, 2020, 1530, 2030, 2630, 3120, 3130, 2120, 2130, 2140, 2040, 2240, 2640, 2840,2150, 2350, 2550, 2750, 2155, 2355, 2555, 2755, maybe more. Some had four piston pumps and some eight. The eight piston pump was part number AR103033. 2020,2510,2520,2030 AG tractors, 300 and 400 industrial tractors usually came with spline-driven pumps, four piston or eight piston.
