Looking for a draft link
JohnnyJohnsoninWI
11-16-2005 08:08:05
Hello,
The left side draft link on my 1520 is badly bent and needs replacing. Actually, I"d like to replace both sides with adjustable draft links. Does anyone know of a (new after market or used JD) source for these parts?
Thanks,
John
Glen in TX
11-16-2005 10:09:20
 Re: Looking for a draft link in reply to JohnnyJohnsoninWI, 11-16-2005 08:08:05
They are available aftermarket in the telescoping style and the adjustable lift rods as well. Most tractor supply places should be able to get them for you local if they check their catalogs. If you don't find them let me know.
JohnnyJohnsoninWI
11-17-2005 04:32:10
 Re: Looking for a draft link in reply to Glen in TX, 11-16-2005 10:09:20
Hi Glen, Thanks for the tip, I'll check around locally.
John
Glen in TX
11-17-2005 09:06:19
 Re: Looking for a draft link in reply to JohnnyJohnsoninWI, 11-17-2005 04:32:10
LH telescoping arm, aftermarket #R3125 and JD # AT30151. JD is over $400 and aftermarket should be less than half that. Shows same one fits 820,830,1020,1520,1530,2020,2030,2040,2240,2440,2630,2640. Good luck.
