Final Drive Model JD25
Al French
11-16-2005 06:15:24
I need the left final drive for a JD 25 or the Cage and Needle bearings to rebuild the unit.
Glen in TX
11-16-2005 21:09:36
 Re: Final Drive Model JD25 in reply to Al French, 11-16-2005 06:15:24
I'm confused? 25 what? Combine, excavator, loader, harvester, picker, sprayer.... JD made more than one 25.. Industrial bearing supply place is usually your best bet for bearings and seals if you have some measurements and numbers off old pieces.
Al French
11-17-2005 02:49:15
 Re: Final Drive Model JD25 in reply to Glen in TX, 11-16-2005 21:09:36
The final drive or bearing parts I seeking are for a John Deere mini excavator Model 25.
Glen in TX
11-17-2005 08:55:08
 Re: Final Drive Model JD25 in reply to Al French, 11-17-2005 02:49:15
I don't know anything about that machine. If you just need the bearings and/or seals and can match the old ones at bearing supply would be great. I'm sure a JD industrial dealer can help with parts. You might also try posting ads or on the crawler/dozer forum here also. Link below to JD industrial site for manuals. Good luck.
