620 needing to be chocked
rdv124
11-15-2005 22:49:13
My 1957 620 gas needs the choke pulled out a little to get it to run smooth, if not it runs like it is missing. Put carb. kit in along with plugs,wires,points ect. Still the same, screw on bottom of carb when turned either way does not change anything, does anyone have any ideas. Help very appreciated, need tractor for this winter moving role bales. Thanks in advance.
MSD
11-16-2005 20:45:46
 Re: 620 needing to be chocked in reply to rdv124, 11-15-2005 22:49:13
There are two small expansion plugs-one on each side- that you have to remove. There is a passage under them that is probably plugged and needs cleaning. I use a gas torch tip cleaning set to get in there. I don't think just soaking it will get it. You can get the plugs from JD yet.
John in IN
11-16-2005 07:59:51
Check fuel flow from tank. There might be rust stopping fuel from getting to the carb. Rust can accumulate around outlet inside of tank.
Carl NY
11-16-2005 07:39:09
This sounds like some of the small internal passages in the carb are plugged. NAPA or Gunk carb cleaner, a gallon size container, take carb apart & let it soak in cleaning solution for a day or two. Remove the float as the solution has a tendacy to attack the solder spots.
Carl NY
11-16-2005 07:38:14
This sounds like some of the small internal passages in the carb are plugged. NAPA or Gunk carb cleaner, a gallon size container, take carb apart & let it soak in cleaning solution for a day or two. Emove the float as the solution has a tendacy to attack the solder spots.
Myrl (PA)
11-16-2005 01:39:41
Probably sucking air around intake push choke in and spray ether or carb cleaner around gaskets between head and intake or it may even be cracked in the heat exchanger which is harder to find
