B
Josh Johnson
11-15-2005 18:18:31
What are the fluid quantities for a 1939 John Deere B? Where are the checkplugs located?
old
11-15-2005 18:41:10
 Re: B in reply to Josh Johnson, 11-15-2005 18:18:31
Should only be to places to check fluid levels. Engine oil should be on the left side just sort of behind the flywheel and forward a little. And the rear end theres a plug you remove and fill to the point fluid runs out. I think your 39 would be the same as my 35 other then yours is styled and mines is un.
