49' B started rod
HoboBob
11-15-2005 14:29:47
I have posted this before, but still havent figured it out totally. The putton will engade starter to flywheel, but will not push button on starter all the way before hitting the bottom of the flywheel cover. If you take the cover off, it will start wright up. Thanks in advance. Hobo
wilamayb
11-16-2005 16:24:04
 Re: 49' B started rod in reply to HoboBob, 11-15-2005 14:29:47
I had the same problem on my 51'B. I just tack welded a washer on the end of the arm that pushes the actuator switch. It has been on there for sevral years. It is covered by a shield, so nobody will know unless you tell.
HoboBob
11-16-2005 16:46:41
 Re: 49' B started rod in reply to wilamayb, 11-16-2005 16:24:04
That sounds crazy enough to work!
JGC
11-16-2005 14:58:10
1. Is it possible that the contacts inside the switch are badly worn and there isn't enough 'travel' to make the contacts 'contact'.
2. Did it work since you got the tractor? If not, could it have the wrong switch installed and the travel of the actuator is too short.
3. I fixed this problem on a friend's "B". There were a few problems that in combination prevented the lever from closing the switch contacts:
a) the cover was dented in
b) the cover had a layer of hard mud/grease inside that limited the travel of the yoke.
c) there was wear at each mechanical joint so the whole thing was out of tolerance.
Jon
HoboBob
11-16-2005 15:17:58
 Re: 49' B started rod in reply to JGC, 11-16-2005 14:58:10
It worked when we got it ealy this fall, The cover isn't dented in, or has any caked on mud-debre. Joints are a posibility. Will have to see.
Hobo
Mike M
11-16-2005 07:17:48
That rod is adjustable down at the bottom. Make it a little longer, remember to tighten up the lock nut.
HoboBob
11-16-2005 12:12:04
 Re: 49' B started rod in reply to Mike M, 11-16-2005 07:17:48
I know what you mean. That part is adjusted fine, but the part that is on the end of the rod, where the swing arm bolts to it, hits the bottom of the cover before it can push the button all the way. It only needs to go another 1/8-1/4 of an inch.
Hobo
Mike M
11-16-2005 20:17:34
 Re: 49' B started rod in reply to HoboBob, 11-16-2005 12:12:04
Never had one bottom out in the cover before ? I've had them bottom out in the slot in the case and was able to bend the tang up some that contacts the switch button to fix it.
