4230 Turbo
H2
11-15-2005 13:33:49
I'm thinking about putting a turbo on my 4230 to increase fuel economy and slightly increase hp. Has anyone done this and if so what did you have to change and were you satisified with the addition of the turbo?
44diesel tech
11-19-2005 22:31:17
 Re: 4230 Turbo in reply to H2, 11-15-2005 13:33:49
I have installed many turbo's on these tractors plus 4040's and 4050's etc. You will increase fuel economy by adding more air thereby getting a more complete/cleaner combustion. If the engine was smoking a little before turbo installation, then turbo will clean it up. I always add a little more fuel'( 10 to 20 %) Note: you will only use more fuel if the govenor is wide open. All my custumers are very happy with the turbo's. Expect to pay around $3000 US.(using all JD parts) Is it worth it ????? Only if you keep it for a long time.
Howard
JGC
11-16-2005 15:06:46
I wouldn't expect to see any improvement in fuel economy by just adding a turbo, unless you make changes to the fundamental design of the combustion chambers, fuel delivery timing, valve timing, etc , etc. I would expect more HP from driving more air and more fuel into the cylinders.
Is there something about turbocharging that I need to learn more about?
G/MAN
11-18-2005 10:44:48
 Re: 4230 Turbo in reply to JGC, 11-16-2005 15:06:46
A turbocharged engine will usually produce very similar fuel economy to a naturally-aspirated engine of the same displacement, while making more horsepower. Since most diesels have no "combustion chamber", at least not one in the cylinder head like a gas-engine, the turbocharging increases the efficiency of the engine all by itself. More air in the cylinder = more heat and compression generated on the compression stroke = a bigger bang and more power. Many of Deeres turbocharged engines use cylinder heads and camshafts that are identical to those of the naturally-aspirated engines of the same size. The turbo tricks the engine into thinking it has bigger intake ports, more valve lift, etc.
G/MAN
11-15-2005 15:27:24
I have a friend with a turboed 4230, and it's not economical. Will burn just about as much fuel as a 4430 he claims, and doesn't make as much horsepower. You won't see any sort of substantial increase in horsepower without turning up the fuel delivery, which is going to increase fuel use.
buickanddeere
11-15-2005 15:26:28
It's cheaper, easier and fewer headaches to trade for a larger tractor like a 4430 or 4630. They sell for less $ per HP than a 30 to 100HP tractor.
