1950 A left main
Eli
11-14-2005 18:07:33
Need help with tecnical question. My left main journal measures 2.747 and is less then .001 outaround. New is 2.748 to 2.750. My lower insert is starting to show the bronze backing about a quarter inch on the outer bottom edge. My question is, Deere only offers one size. Can this one be used or does it require fitting by a machinest. I also have available one out of a parts tractor that looks ok. A friend said flip the top to bottom because the top looks good. I would rather use new but will do whats best. Right side main in excelant shape. Mine has the thrust washer attatched to the insert.Thank you any comments appreciated, Eli
Eli
11-15-2005 19:11:38
 Re: 1950 A left main in reply to Eli, 11-14-2005 18:07:33
Thanks for the input. Mine does have shims. I agree the old ones flipped probably not a good idea. I wish I new for sure if the new ones needed fiting. Deere says they are a non refundable part not sure why. At $109 wouldn't want one I couldn't use.
Mike M
11-16-2005 07:21:20
 Re: 1950 A left main in reply to Eli, 11-15-2005 19:11:38
FOR SURE no special fitting , but will need to adjust the shims.
JD man inSD
11-15-2005 19:02:17
flanged insert is for left main flywheel side
Mike M
11-15-2005 04:57:54
If you can still get the new inserts you will be better off. They do not need special fitting just adjustment by the shims.
Kevin L.
11-15-2005 07:06:38
 Re: 1950 A left main in reply to Mike M, 11-15-2005 04:57:54
my understand is all main bearing replacement require machining to size the new bearing to the crankshaft, now for flipping the old over I dont know if the oil hole would line back up and you would have probably run a lower oil pressure at that bearing. would think the left bearing would show more wear, the most weight on a dry startup.
Mike M
11-15-2005 10:05:42
 Re: 1950 A left main in reply to Kevin L., 11-15-2005 07:06:38
You are thinking of the one piece style that are like a bushing made from aluminum. Those are found on later tractors.They need to be bored out to fit after being pressed into the housing.
