1949 JD A- Proper Rear Lighting
ol' guy
11-14-2005 17:08:27
I'm just starting restoration of this tractor made in Sept,1949. What is the proper or acceptable rear light configuration? I have the parts book, but I see no serial number designation for the different lights shown. If anyone has researched this, or if you have an original tractor of this age, I'd appreciate knowing what sort of rear lighting is present. Thanks in advance!
Matt@miller
11-15-2005 16:49:46
 Re: 1949 JD A- Proper Rear Lighting in reply to ol' guy, 11-14-2005 17:08:27
There is Three different rear light set ups for the late A, the most common one and everyone uses is the light with the little red light inside and the switch
the different lights are:
A work light: a light with no red light inside of the light or a switch, The light housing has one terminal and no switch
A combo light with the little red light inside and the switch. The light housing has one terminal and a switch
the last one is the a light with no red light in side and then a ballet light bolted to the side of the battery box. This light housing that bolts to back of the battery box has two terminals and a switch.
One is interested is all these light sub to a Combo light with the red in side and a switch.
HoboBob
11-15-2005 14:35:09
Our 49' B has a singe light Connected to the back of the battery box. it was originaly hocked up to the whole lighting system, be we put a seporite switch on the side of the box. The tractor is all original exsept for the switch. It is a regular light like the ones up front(not red or bullet).
Hobo
G/MAN
11-15-2005 10:20:20
If you'll actually be driving the tractor on the road (or even off the road for that matter) when it's dark or even during periods of questionable visibility, I'd strongly recommend upgrading the factory rear lights. They're a long way from being up to today's standards, and decent lighting can be added without having to "butcher" anything on the tractor. I'd have a minimum of a bright red taillight located on the extreme left side of the tractor, and at least one flashing orange warning flasher, in addition to a good SMV emblem. And some red/white reflective tape sure wouldn't hurt either. Some doofus tooling along at 50 mph and not seeing you could ruin your day quick.
DickD
11-14-2005 18:14:17
The only setup I ever saw on the late model A's was a single light with a switch on it, that switched it from a light to work at night with, to a red light for traveling on the road after dark.
Walt in Jaxn Tn.
11-14-2005 20:36:07
 Re: 1949 JD A- Proper Rear Lighting in reply to DickD, 11-14-2005 18:14:17
I have parts book PC-RA1-(3-50)Revised, including (serial No. 584000-)shows 12 volt light, no switch, part # AA 3867 R lamp rear, key 27 and AA 4529 R lamp, rear, with switch key 28 and lamp, wiring, with Attaching wire key 30 (this is a bullet light) So acording to a parts book printed in march of 1950, you could have a plain light or a switched light or a switched light with a bullet light. Hope this helps --Walt--
