720D Camshaft Washer
Kevin L.
11-14-2005 15:08:39
on the 720d camshaft I have tabed flat washer on the end with the gear and need some clearification. most tabed washer are usually keyed to the shaft so the tab will bend up to the nut to hold it. So I want to make sure that it's not suppose to put the tab in a notch in the cam drive gear and tighten the nut down that way. since the washer has a round hole in it. thanks...
buickanddeere
11-14-2005 22:25:32
 Re: 720D Camshaft Washer in reply to Kevin L., 11-14-2005 15:08:39
Watch the cam to injector roller alighnment. The rollers have to run on the center of the cam lobe, not off to one side. Or be faced with early wear, loss of power and a rough running engine. More common problem than most people suspect.
F-I-T
11-14-2005 19:38:41
third party image
Do you mean this one? It's just trapped between the nut and the gear, and then you bend one flap down on the nut flat. I guess they figured the gear surface was keyed so it wouldn't move, and the nut was kept from turning by the trapped locking plate so it should never come undone.
Frank
Mike M
11-15-2005 05:02:02
 Re: 720D Camshaft Washer in reply to F-I-T, 11-14-2005 19:38:41
The picture appears to show a tang on it ? and if so it should go into a hole or keyway on the gear. It has to have something to hold it. As extra safety on mine I also used loctite wick and lock after assembly.
Kevin L.
11-15-2005 06:54:15
 Re: 720D Camshaft Washer in reply to Mike M, 11-15-2005 05:02:02
I have no way of knowing which way because in removing the side cover the nut and washer were in the bottom. the best my eyes can see is the picture shows the tab pointing at the gear and in a trail fit the washer would not sit flat because the tab bottom out in the hole on the gear. I have to remove the gear to remove the idle gear to check the bearing or shaft in it, it's loose and showing ware marks on the face.
