730 Pony Carb Problem
Larry T
11-14-2005 13:31:41
No start after sitting 1 year.Discovered no gas at bowl bottom plug.Gas comes out at sediment bowl but not to carb. depressed knob on oil pressure switch to allow gas to enter carb but no luck. Finally poured a little gas into carb throat and motor fired right up. Ive got a new gas hose to carb so this isnt the problem . Thanks for any help
Blksmok
11-14-2005 18:18:13
 Re: 730 Pony Carb Problem in reply to Larry T, 11-14-2005 13:31:41
Larry...needle valve is probably stuck in the seat. This will keep gas from entering the float bowl. Remove the gas cap on the pony engine gas tank and use compressed air or your own lung pressure to "pressurize" the system. If it "unseats" you should see gas coming out of the plug hole on the bottom of the bowl.
F-I-T
11-14-2005 18:41:43
 Re: 730 Pony Carb Problem in reply to Blksmok, 11-14-2005 18:18:13
Blksmok:
This is funny. I have one just like that right now on a 70D Std, but is seeps just a little, so if you let the bowl fill, the pony will run great for about a minute, then stumble and die. I'm going to take it apart and rebuild it, as it has got wet (water in the tank) and probably has rust and crud in it, but I agree, the float needle is stuck. You might lightly tap on the carb bowl area (flyhweel half of the carb) and it might shake loose. Then it might not seal again.....
Frank
Kevin L.
11-14-2005 14:58:21
it could be the low slope of the hose from the strainer to the oil pressure valve or if the 730 is like the 720 it should have a shut-off before the oil pressure valve and handle sticks out probably below the dash and if closed.
