Uneven idle
Ben Hodges
11-10-1999 18:39:14
I have a l950 John Deere AR runs great but on a slow idle the govenor seems to kick in for an instant to catch up speed. It's hard to explain but by just putting your finger on the throtle shaft and holding it back just a little is is smooth. You can drive the tractor while idling in 3rd grear and it is smooth? Is there a governor spring or something thats puts a little tenchion on the throttle that would stop this? Thanks for any idea on this. Ben - Michigan
Dave Wickman
11-11-1999 07:35:31
 Re: Uneven idle in reply to Ben Hodges, 11-10-1999 18:39:14
Ben, In your case where the tractor will idle with the carburator arm held in an idle position, I would say your problem was binding of the throttle control rod between the carburator and the governor arm. The rod must fit freely in holes of the carburator and govornor to work right. (Check it through its complete travel from low idle to high idle for binding) also check the control rod to see that it is not rubbing or interferring with anything. If this appears to be correct I would check the control arm shaft where it pivots in the governor case. A can of penitrating oil might fix your problem or an adjustment of the throttle control rod. Correct length adjustment of the throttle control rod is 1/2 hole short of fitting into hole of carburator with the carburator and throttle lever in the wide open position. Good Luck!! Dave
