'H' Carb
Walter Squires
11-14-2005 11:57:28
I'm stumped, I can not get the load nozzel out, tried threading and a puller, heat, etc. that little long brass SOB will not move. Any body got a rabbit up there sleeve for this one?
AllenS
11-18-2005 15:06:21
 Re: 'H' Carb in reply to Walter Squires, 11-14-2005 11:57:28
I use bees wax. Heat the area around the part that you need to remove with your propane torch, then add some bees wax to the part, watch it bubble, heat more, add more bees wax. I used this method to free up some brake lines on a 1966 car. The lines wouldn't come lose even after I had soaked them in penetrating oil for 4 days. The bees wax method worked.
Deerely B Parted
11-15-2005 06:31:34
Pat Browning will set you straight! Might be timely to review his procedure which I used on my DLTX, '50B: Take (in this case) a 10-32 tap and thread the brass member from the bottom, then screw a stud into the newly created threads and (with the use of a "strongback" across the carb body)gradually tighten. works slick as snot. Joe Howard
Glen in TX
11-14-2005 13:00:48
It's going to take more soaking with carb cleaner in a bucket and penetrating oil to get it loose. Sometimes they do get really stuck bad and you have to replace them because they get destroyed removing but it isn't going to run right or at all if all that crud isn't cleaned out behind it.
Mike M
11-14-2005 12:57:20
When you say heat did you use just a small propane torch or an oxgen acetylene type ? Those small ones don't get hot enough fast enough.
I've removed some real tight ones with a slide hammer puller and heating the outside of the stem that houses it.
Walter Squires
11-14-2005 13:33:35
 Re: 'H' Carb in reply to Mike M, 11-14-2005 12:57:20
I used oxy-acet and had that sucker RED..... .
Pat Browning just e-mailed me with a procedure that I'm going to try, he generaly dosen't lead me a stray too far. I guess I should just have looked at his book first, you know what they say when all else fails read the book. Thanks P.B.
Walter....
F-I-T
11-14-2005 13:45:36
 Re: 'H' Carb in reply to Walter Squires, 11-14-2005 13:33:35
Walter:
I have Acetylene available, but Propane has always worked for me (the best is to lay it on your charcoal grill overnight!), but you need to warm the whole thing up and then let it cool down over the course of a tv show or two, then heat it again and let it cool all the way down again. Then thead your bolt in there and it will come out. The heat/cool cycles is what seems to do the trick.
Frank
Walter Squires
11-14-2005 13:58:44
 Re: 'H' Carb in reply to F-I-T, 11-14-2005 13:45:36
Hey Frank, might be a good excuse to burn a few T-Bones on the grill tonight..... .
F-I-T
11-14-2005 14:28:06
 Re: 'H' Carb in reply to Walter Squires, 11-14-2005 13:58:44
If you don't mind the varnish flavor....Oh! You mean to cook the carb AFTER the steaks. I gotcha....
