M-S carb on 1520, rebuild expectations
JohnnyJohnsoninWI
11-14-2005 09:44:29
Hello,
I have a Marvel Schebler TSX-944SL 71F carburator on my '71 JD 1520. It starts and runs good, but it is a thirsty tractor. When the governor opens up, it belches a black cloud from the exhaust.
I've searched the internet and ytmag's archives extensively, plus contacted both Denny's and Robert's carb repair shops, yet I still don't have any idea if it's worth the trouble and expense to rebuild my carb.
A friend told me that he had Denny's rebuild the carb on his 3020 and ended up with about a 30% reduction in fuel consumption when plowing.
I've also read that the electronic fuel solenoids are generally discarded during rebuilds in favor of a manual needle, but I still don't understand why. Do the solenoids tend to allow excessive fuel consumption? Why don't you guys like the solenoids?
I get the feeling that most of the posts here regarding carb rebuilds are related to tractors that don't run right or don't run at all. Is there any advantage to rebuilding a carb on a tractor that already runs pretty good? I'm not looking for more power, just reliability and economy.
Thanks,
John
Glen in TX
11-14-2005 13:21:17
 Re: M-S carb on 1520, rebuild expectations in reply to JohnnyJohnsoninWI, 11-14-2005 09:44:29
Some of the solenoid needles are adjustable and some are not. If the needle is worn it may need replacement. Some can also be cleaned out and the solenoid jet and carb may just need cleaning and adjusted. A kit and cleaning the carbon and crud out of all the passage ways should help some along with a good tune up. A Zenith 14997 carb is available to replace that one also. Make sure your airway to carb is clean and clear also.
Mike M
11-14-2005 10:05:23
If it runs good otherwise you may just need to readjust it ,they do change.
