Ben: The flywheel is opposite the pulley side of the engine, or the left side. If you remove the shield (not sure if it can be slid off on a 110), you can remove the screen mesh, and see the nut that hold the flywheel to the crankshaft.v You could turn the engine that way, or turn it using the bolt that is in the center of the pulley stack on the belt side. On your starter, first try jumpering across the solenoid from one large terminal to the other. That way you can determine if the starter will crank without the solenoid before you disassemble anything. If that makes the starter work, it's now either no power getting to the solenoid, or the solenoid is bad. It's an old Ford type fender mount unit. Pretty cheap at Autozone, etc. You can back up one step and put power to the small side terminal on the solenoid. If that works, you are not getting proper power to the solenoid switching terminal. TRack down the power from the keyswitch to the solenoid. The switched can and do go bad, as well as the individual wire terminals. I have replaced lots of them, and I solder them on. Since you have it clicking, my guess is it's either the solenoid, but more than likely the starter. They are pretty much a disposable unit. You can get them from Deere, but also from other small engine places on the internet, sometimes at a lower cost. Frank
