4430 in photo ads
wilamayb
11-13-2005 19:26:40
What about a 4430 with an intercooler!!!! Has anyone else done this conversion? It looked like a JD intercooler. Is it a dealer add on or is it a junkyard add on?
JD man in SD
11-14-2005 04:15:51
 Re: 4430 in photo ads in reply to wilamayb, 11-13-2005 19:26:40
i would get one in junk yard. use 4630 model
pbutler
11-14-2005 15:26:19
 Re: 4430 in photo ads in reply to JD man in SD, 11-14-2005 04:15:51
I think the only difference in the engine between a 4230 and 4430 is the turbo. And the only difference in a 4430 and 4630 is the 4630 added the intercooler.
G/MAN
11-15-2005 10:49:42
 Re: 4430 in photo ads in reply to pbutler, 11-14-2005 15:26:19
The 4230, 4430 and 4630 all use the 6404 engine. The 4230 the 6404D (naturally-aspirated), the 4430 the 6404T (turbocharged) and the 4630 the 6404A (aftercooled). There are many different components used in each, though. 4230s had a cylinder head with a different intake port design, which was similar to the later 466 heads, etc.
msb
11-14-2005 16:40:34
Injection pump specs are diffefrent between the 4430 and 4630 and I think the water pump and air cleaner are a bit bigger on the 4630.
macleod
11-14-2005 23:18:48
 Re: 4430 in photo ads in reply to msb, 11-14-2005 16:40:34
There are many more differences than you would think, heavy duty steering motor more plates in clutch and quad planetary etc
