Valve clearance G JD
Richard Heyduk
11-13-2005 17:37:13
I need some expert advice here. I want to adjust the valve clearance on my 1951 "G" JD. The original owner's manual says to adjust at .020 with engine cold, the IT manual says adjust at .020 with engine hot. Which do I use here?
buickanddeere
11-14-2005 08:05:48
 Re: Valve clearance G JD in reply to Richard Heyduk, 11-13-2005 17:37:13
As Mike said. Unless the valve stem tip and rocker arm tips are perfectly flat. Checking valve lash with a flat feeler gauge will leave the valve adjusted too wide. Measuring lash via how much the lock nut turns is a viable alternative.
Mike M
11-14-2005 06:16:28
You set old JD's .022 cold and then that ends up .020 hot Resurface the rocker arm faces so you get an accurate measurement.
JD man in SD
11-14-2005 04:18:53
use cold setting Deere knows what they are doing
Duane Larson
11-13-2005 19:44:41
Richard,
Since JD printed the owners manual and was responsible for the info in it, I would go with the info there. Also, the original I&T hardbound service manual gives the tappet clearance as 0.020" cold for the G.
The JD Field Service Bulletins just list 0.020 without any reference to hot or cold, so I would assume that meant cold as set during the overhaul process.
