Fuel Strainer for JD730D CE Gasoline Tank
Ken C
11-13-2005 13:15:40
I have what I think is the original Bendix fuel strainer on my 730. I ordered a new bowl gasket (F3644R) from Deere and it is too big (1-1/4" od). The bowl on my fuel strainer is 1" od. Where can I get a gasket to fit my strainer? Do I have the correct fuel strainer on my tractor? TIA!
F-I-T
11-13-2005 15:12:48
 Re: Fuel Strainer for JD730D CE Gasoline Tank in reply to Ken C, 11-13-2005 13:15:40
I bought one last year for a sediment bowl on a 70D (it was added later and appears to be just like the 720/730 factory unit). The bowl assembly says Tillotson, Toledo. I had it apart today in fact.
Maybe JD have mispackaged one.
Frank
Ken C
11-13-2005 17:39:16
 Re: Fuel Strainer for JD730D CE Gasoline Tank in reply to F-I-T, 11-13-2005 15:12:48
My assembly says Bendix Zenith. I bought two (2) F3644R bowl gaskets several years ago and they are both the same size. Is your bowl 1" od? Thanks!
F-I-T
11-13-2005 17:54:07
 Re: Fuel Strainer for JD730D CE Gasoline Tank in reply to Ken C, 11-13-2005 17:39:16
Ooooh. I won't be able to check until tomorrow.
F-I-T
11-13-2005 17:56:44
 Re: Fuel Strainer for JD730D CE Gasoline Tank in reply to F-I-T, 11-13-2005 17:54:07
BTW, you can most likely get the gasket you need at a Kohler or Briggs and Stratton dealer. Older engines used sediment bowls like that, and even some of the gas tank caps used a smaller cork gasket. I once stole one out of small 1 gallon gas can I have on the shelf until I could get to town and buy what I needed.
Frank
Ken C
11-14-2005 16:47:49
 Re: Fuel Strainer for JD730D CE Gasoline Tank in reply to F-I-T, 11-13-2005 17:56:44
Thanks for the suggestion to check with a small engine shop. I am ordering another gasket from my JD dealer to see if I get the correct one. BTW, which do you think is better, a cork or rubber gasket? I am leaning toward a rubber one.
F-I-T
11-15-2005 03:33:58
 Re: Fuel Strainer for JD730D CE Gasoline Tank in reply to Ken C, 11-14-2005 16:47:49
Personal preference, but on fuel, I like cork, but I guess it doesn't matter.
