Hi Steven, I'm more familiar with the "D"s but here is what I would check out:1. Make sure that you are in fact using the correct fill line. It may be stamped on the bowl. 2. 30 weight oil is what I use, that should be OK. 3. My filter assy was so clogged with crud that steam cleaning wouldn't get it cleared out. I took it to a rad shop and they soaked it for 2 days to clean it. Now when you look thru it you can see daylight thru the mess. Someone on this site said that they can get so bad that they have had to cut them open to clean them. I don't want to go that far. 4. My guess is that the filter medium is clogged and the intake air is travelling at high velocity thru a small area of the filter and carrying oil into the intake and carb. 5. Check in the parts book to make sure that you aren't missing any deflectors or baffles that might have been lost. (The oil filter on my "D" was missing the big flat disc that goes under the paper filter element and the outlet pipe that holds the element at the filter head. Oil was been pumped past the element - none was being filtered.) 6. Other folks may have some other ideas specific to your model. 6. By the way, I would never run it without oil in the air cleaner. The mesh filter medium is very course and relies on the oil to catch the really harmful dirt and grip. Without oil, it's only stopping the largest particles. Many farmers didn't keep up with the service and that's part of the reason many of these old engines are so badly worn inside! I fellow I know bought a small Cat D2 that was run in a quarry without the air cleaner - ruined the engine in no time! Hope this is of some help! Jon
