4020 with detroit diesel
jd9295
11-12-2005 19:20:05
Just saw an ad in a local sell all paper we have around here. It is for a 4020 with cab and with a 6-71 detroit in it????? The ad says there were around 3000 made I believe. Never seen or heard of this anyone else?
Glen Anderson
11-14-2005 12:27:27
 Re: 4020 with detroit diesel in reply to jd9295, 11-12-2005 19:20:05
I think I've seen other tractors (Oliver I think, maybe Cockshutt?) with that same 6-71 conversion. Anyone else know about these conversions and who offered them, just curious?
They were definitely noisy, had a narrow power band, and liked to leak, but they were very dependable engines and would take more abuse from cold starting and abuse of ether than any other 2 or 3 - 4 stroke engines would combined.
hardscrabble
11-14-2005 07:12:04
Several years ago a few farmers around here put that engine in 5010/5020 tractors, but NEVER in a 4020. It eventually tore up the drivetrains on those tractors, too.
Brand0n
11-13-2005 19:12:12
A 6-71 in anything is going to make a mess of the drivetrain unless its designed for the task. They were torque monsters but only in a very narrow speed band and I have seen gears busted during the torque rise as the engine builds speed and falls into its powerband. Anything lower than the powerband the 6-71 is well known for large volumes of protest smoke being the narrow minded machines they are.
If this guy did drop a 6-71 into a Deere anything its only going to live a short while. Dropping a 6-71 into a 4020 would make for a difficult to service tractor not to mention none of your crops are going to be worth eating in the first place thanks to the perpetual oil leaks that seem to follow every 71 and 92 cid/cyl 2-stroke that Detroit ever made.
Brand0n
bison
11-13-2005 14:00:47
one hell of a engine to put in a 4020.
they might be noisy but they have a lot of low end torc , it will pull this tractor right to shreds without trying hard
JD man SD
11-13-2005 08:07:35
NO way detroit from Deere this has to be a conversion deere built all 4020s wlth own engine
John T
11-13-2005 05:54:06
Another thing I wouldnt like about a leaky old Detroit is they need to keep their RPM up to develop their rated HP and are not known as luggers which is more typical of a desired tractor engine trait I would think.
Back years ago when we ran some trucks the 318 V 8 Detroit and the in line 6 -71 (like many old busses used) all leaked and you had to keep the RPM up in them. I think the 8V92 were an improvement, but they eventually dropped the 2 cycle claiming they couldnt get them in line with the new pollution regulations or something, not sure. As far as in line diesel, its hard to beat a Cummins although Cat makes good stuff but parts are pretty salty. If I wanted a truck to make money, however, I think I would run a Mack
even if not as classy as a Pete or KW
John T (NOT a Detroit fan)
buickanddeere
11-13-2005 11:54:15
 Re: 4020 with detroit diesel in reply to John T, 11-13-2005 05:54:06
Come on John. I live to hear the wailing scream of a Detroit two stroke hitting the redline. On a Detroit the HP output is pretty much linear with rpm as the torque curve is virtually flat. It's always running at near peak torque. So the more rpms then yes the more work she will do. A four stroke is running out of breath and is past its peak volumetric efficiency when running at peak HP rpms. As the four stroke is lugged towards the peak of its torque curve the volumetric efficiency improves. It does allow the option of riding through a tough spot without having to down shift. Electronic fuel injection does allow the manufacture to build in the appearance of torque rise that the engine doesn't actually have. Max fuel flow at any rpm is limited to how much airflow/volumetric efficiency at those rpms. So yes the electronic engine gets and burns a larger squirt of fuel at peak torque/peak airflow. Than it does when the airflow per rpm begins to drop at higher rpms. Here is the sound of my 435�s 2-53 Detroit pulling down the track. It just happens to be labeled �Big Red Express� 1.3 Mg file size. >Link
>Link
buckeye al
11-15-2005 15:32:56
 Re: 4020 with detroit diesel in reply to buickanddeere, 11-13-2005 11:54:15
Started to offer two cents & typed up a whole buck fitty! Sorry Guys.
Put any tractor on the dyno at a show powered by a 3-71 or 2-53 & you will draw a crowd!
No machine I've ever hooked to my dyno has ever had the flat response to load of the 2 cycle Detroits! They hold on and keep going 'till the very edge then down they go on RPM. Up to that point they're flat & "put their shoulder to the load" like nothing else.
Can't imagine running an Oliver Super 99 D all day but then the guys that own them can't imagine running my 70D all day either so that's a wash!
Ran one on the dyno this fall that just does parades. He backed up to the dyno with lots slobbering & white smoke. Pulled it to about a 25 horse load for what seemed like forever waiting for the temp to rise to normal. I don't put MY tractors on big loads unless warmed up and refuse to do it to anybody else's. Anyway... Made lots of smoke that showed no signs of letting up but when the temperature gauge said OK, we let 'er rip.
At about 65 horse the slobbering was so bad strings of gunk were streaming out of the manifold (he'd removed the muffler) and we had LOTS of smoke billowing across the grounds. Mothers were holding their hands over their children's ears.
At about 75 horse very suddenly the slobbering stopped and the silvery white paint he'd put on the manifold changed colors. No more slobbering but a rain of slimy soot balls started. PTO speed had only dropped about 25 RPM. After a few minutes it peaked at 80 HP and the soot balls were really flying! Mothers were on their knees insisting their children cover their ears as they covered their own!
After several minutes the soot balls started to subside. Peak was now up to 85 HP. Women & children had gone to the flea market area.
We left it on the 80 to 85 HP load for roughly 10 minutes as we waited for "the rain" to stop. No more soot balls, no slobbering and it now peaked at 87HP. As the wife would say, all that was left was a bunch of farty old farmers grinning, watching and for some reason yelling at each other! (I cheated. Had ear plugs!)
I don't know how accurate the actual HP numbers are & I always encourage owners to look at the difference between numbers (peak at beginning of the run -vs- peak at end of run) more than the biggest number but you know how that goes.
At the end of the run the tractor was turning 565 PTO RPM no load and put out 87 HP at 535 RPM. It had given its all by 530 and was rolling off fast.
Yes they're noisy, yes they seem to grow leaks, yes they're a breed all their own. Worthy of great respect? I believe so. Capable of lots of work? Sure. Run 'em hard & they'll come back for more. Usually an easy start. They're as unique as the 2 cylinder Waterloo tractors. Maybe good for this but not so good for that. Maybe unexcelled at still another application or task.
I enjoy all machines and perhaps the more unique, the closer to my heart. Hope you enjoyed the story.
Later.
buickanddeere
11-13-2005 05:17:49
Maybe 3000 conversions but that would be a stretch. How long will a drive train designed for 98HP going to last with an engine capable of 190-210HP at 1800rpm?
jd9295
11-13-2005 05:33:05
 Re: 4020 with detroit diesel in reply to buickanddeere, 11-13-2005 05:17:49
kinda what i was thinking, it looked like one to avoid
