1947 B PowerTrol
JaredM
11-12-2005 18:10:54
Can someone explain to me PowerTrol. I'm restoring my grandpas 1947 B and want to know how it works and how it varies from other hydraulic systems. I'm assuming it has special tips but does it have a special cylinder it uses or is it compatible to any. Pics of the stuff if there are any unique parts would be helpful also. Also what were other options besides Roll O Matic, 3 point hitch, and PowerTrol beacuse it has all those. Any help would be appreciated. Thanks. JaredM
Glen in TX
11-13-2005 22:46:01
 Re: 1947 B PowerTrol in reply to JaredM, 11-12-2005 18:10:54
Jared, One of the best things you can do to help yourself in a restoration is to get some manuals for your tractor. Operators manual and a I&T JD4 shop manual will cover a lot to help you and a parts catalog and other JD shop manuals can help even more. Most all two cylinder hydraulics are covered in the JD SM2011 Hydraulics shop manual and it is much more extensive in coverage of the hydraulics repair and wear specs than the I&T manual. It covers power trol, power lift, pumps, and lift cylinders of the two cylinder era. These hydraulic systems didn't have the higher pressure like todays systems and will work with newer cylinders also but just runs them some slower. The older hydraulic cylinders didn't use as high of pressure.
