620 hydraulic pressure adjustment
oldfartathart
11-12-2005 13:14:16
Can anyone tell me if the relief valve on a JD620 is adjustable? I do not have any manuals for my tractor and I'm trying to get a little more psi to run my splitter. Also, if it is adjustable, where do I find the adjustment. I have found what appears to be an adjustment screw (under a deep cap nut) going in the right upper side of the power-trol, but I don't want to play with it without knowing what i'm doing first (it is currently screwed all the way in). Thanks for any advice.
Mike M
11-14-2005 13:07:36
 Re: 620 hydraulic pressure adjustment in reply to oldfartathart, 11-12-2005 13:14:16
I don't think that is the pressure adjustment as you usually need to add shims to adjust it. They only run around 1500 anyhow so even at rating not enough for a splitter. Even the I & T books will have that info see if your local TSC or Rural king has one. I don't have mine with me or I'd tell you for sure.
buickanddeere
11-12-2005 17:58:44
Sounds like the pump maybe worn or the oil is very thin and the system can't build enough pressure to break anything when the relief valve is bottomed out. You will have to bite the bullet and purchase the manuals from 1-800-522-7448. Then get a 2000psi max pressure gauge and some fittings, a valve and pioneer fittings. If the system won�t make rated pressure than a pump re-machining and rebuild is required.
oldfartathart
11-12-2005 18:25:27
 Re: 620 hydraulic pressure adjustment in reply to buickanddeere, 11-12-2005 17:58:44
Thanks for the reply. Although it's not very good news, I appreciate your advice. By your information I am gathering that the screw I refered to is indeed the adjuster for the relief valve?
You are right, I certainly would benefit from spending some cash on manuals. As for my pump issue, I think I'll just buy a pto pump to run the splitter rather than a new pump for the 620. The tractor is more of a toy (I pull w/ it) than anything else, and I would get better performance out of a separate pto pump anyway. (probably for less money, too). Thanks again, Scott
