4520 stuck in gear
JD Jerry
11-12-2005 04:57:22
My 4520 was stuck in park so I pulled on the shift lever and got it in first gear and drove it ahead a few inches, stoped and tried to put it in reverse but it is stuck in first. The lever is solid. I unhooked the linkage and can move the range station but cannot get the upper shift arm to move. I pulled the tractor back and forth with the clutch pushed in but it will not release. Local mechanic said to put it in a higher range and drive it around to see if it will come out. Is this safe or will I have a bunch of parts floating around in the tranny? The tractor has always shifted good and I have had it stuck in park before but it would release.
JD Jerry
11-13-2005 07:02:01
 Re: 4520 stuck in gear in reply to JD Jerry, 11-12-2005 04:57:22
I did like the mechanic said and it came right out. He said that I better take the floor out of the cab and pull the tranny cover. There should be a bolt broke in the shifting cam. He has worked mainly on deers since the 50"s.
JDBert
11-12-2005 12:38:37
I would say its probably a worn shift collar. My 4010 is getting REAl bad about this especially in 3rd and 5th. What I usually do is work it back and forth real easy, or somethimes "pop" the clutch a couple of times.
