1951 John Deere G gas tank
gu41
11-11-2005 19:32:21
I finally got the sediment bowl out of the gas tank on the JD G. The tank had a lot of rust in it and the bowl was hard to remove. It appeared the threaded nipple in the tank turned some when I was working it back and forth. Can someone tell me how the nipple is attached to the tank and if it should leak an easy repair?
960
11-11-2005 20:19:51
 Re: 1951 John Deere G gas tank in reply to gu41, 11-11-2005 19:32:21
When I have that happen I take it to the local radiator shop to have it cleaned, the nipple resoldered, and then inside of tank sealed. Cut corners and you are going to have priblems. Good quality salvage tanks are getting hard to find and pricey.
gu41
11-12-2005 19:43:26
 Re: 1951 John Deere G gas tank in reply to 960, 11-11-2005 20:19:51
Thanks 960 for your good advice.
