310B Backhoe changing hydraulic / trans oil
Gunderlaney
11-11-2005 17:28:04
Have correct oil and filter to change my hydraulic / transmission oil, as current oil is burnt and don't know when it was last changed. Was wondering how was the best way to get as much of the old oil from the system as possible. Is there an easy way to get the bulk of the oil from the hoses and not simply draining the oil that is back in the sump?
Roy Suomi
11-11-2005 20:39:22
 Re: 310B Backhoe changing hydraulic / trans oil in reply to Gunderlaney, 11-11-2005 17:28:04
The best way I know is to raise hydraulics all the way up, drain the transmission case. There are a couple of plugs to remove on the bottom.Lower raised hydraulics, this will expell the crappy oil from the cylinders, into the trans case and drain into buckets . Several refills and drains should clean things up.
