4020 fuel in oil
Glen Anderson
11-11-2005 17:00:08
Our 4020 has ended up with large amount of fuel in the engine oil. I've checked the transfer pump(diaphram type) and it is definitely not the source of the contamination, leaving only the injection pump as the source. Is the injection pump driveshaft seal known to leak or would that be a rare occurance? Is there any way of testing for driveshaft seal leakage without removing the injection pump? Also, if the seal proves to be faulty, what is involved in changing it?
Thanx in advance
Glen
jdemaris
11-12-2005 11:35:06
 Re: 4020 fuel in oil in reply to Glen Anderson, 11-11-2005 17:00:08
You didn't mention which model injection pump you have - 4020s used eleven different pumps made by Roosamaster of the DB/JDB series or the totally different C/CB series. The DB/JDB has two umbrella seals riding against a bronze bushing. To repair, the pump comes off, gets taken apart, bushing and two seals replaced, and at the the least the plastic weight retainer and fuel-regulator plug replaced. Total job, start to finish for someone with experience, is about three hours. I've done many, on site, at farm, field, or in the woods. Parts would include the seal kit and the bronze bushing - $28 plus $11. If it's a model C/CB pump, it uses a conventionl oil seal or seals. It can be replaced easily, once the pump is off, by unbolting the front housing. With the pump off, it's a ten minute job to replace the seal - and another hour of removing and reinstalling the pump. 4020s used the following pumps: CBC633-AL, 18AL, 24AL, 28AL, DBGVC633-1AJ, 3AJ, 5AJ, JDB633AL2402, 2404, 2719, and 2721.
Glen Anderson
11-12-2005 14:44:49
 Re: 4020 fuel in oil in reply to jdemaris, 11-12-2005 11:35:06
Thanx for the reply, my pump # is DBGVC633. The part that aggravates me about this is that this injection pump is a reman unit I installed a little over a month ago. I guess I'll remove the the pump and inspect the bushing after I remove the shaft, hopefully it'll be in good shape. With any luck it was this umbrella seal that may have been damaged during assembly and that'll be all I'll have to replace. Can the seal kit be purchased from Deere?
jdemaris
11-12-2005 18:16:46
 Re: 4020 fuel in oil in reply to Glen Anderson, 11-12-2005 14:44:49
We used to buy the kits from Deere, but I doubt you can anymore. Any diesel pump shop can sell you the kit, they still cost around $28. If the pump was done recently, it's likely someone flipped the edge over on the umbrella seal closest to the pump. You can buy the seals separately if desired - without getting the entire kit.
Glen Anderson
11-14-2005 09:42:49
 Re: 4020 fuel in oil in reply to jdemaris, 11-12-2005 18:16:46
Thanx again for the reply, I removed the injection pump last night and found the umbrella seal facing the fuel side on the pump driveshaft was torn in 2 places, that'll definitely answer for the fuel in the oil.
Now, I need to get some parts rounded up.
Glen Anderson
11-25-2005 13:02:36
 Re: 4020 fuel in oil in reply to Glen Anderson, 11-14-2005 09:42:49
I replaced the faulty seals and installed the injection pump last weekend. While I was at it, I had the re-man/reconditioned injectors I purchased with the pump several months ago tested at the local JD shop(I was leary). 3 out of the 6 ended up leaking/dribbling before cracking pressure, so I ended up returning them to where I purchased them and replacing them with OEM injectors.
I guess in this situation it didn't pay to "cheap out", although had the components worked out I would've stood to save quite few bucks.
Oh well, I'll know better for next time.
msb
11-11-2005 17:51:35
When the diaphram goes bad in the transfer pump, the fuel will wash the inside of the pump squeaky clean. Worn out pump shaft seals are a very common problem in those pumps.The pump shaft bushing could also need replacing.IF the bushing is cut out pretty bad then the pump has to be almost totally dismantled to replace the bushing.The bushing will need to be pressed out and pressed and epoxied back in .It takes special tools to set the height of the bushing in the pump housing.Don't be surpriced if it needs extensive repairs on top of new seals.
davisfarms
11-11-2005 17:23:09
I WOULD CHANGE FUEL PUMP BEFORE EVEN CONSIDER INJECTOR PUMP 10 TIMES OUT OF 10 IT IS THE FUEL PUMP AND IT IS THE CHEAPEST TO FIX LESS THAN 50BUCKS. THEN THIER WILL BE NO DOUBT IF IT IS INJECTOR PUMP IF IT IS LIKE MOST 4020 WHO HAVE LESS THAN 1MILLION HOURS
Glen Anderson
11-12-2005 07:49:43
 Re: 4020 fuel in oil in reply to davisfarms, 11-11-2005 17:23:09
Thanx for the replies.
I've already checked my transfer pump, I removed it from the tractor and performed a bench test of sorts by connecting a hose to the suction of the pump and allowing that hose to draw from a container of fuel, I plugged the outlet of the pump and manually stroked the lever on the pump until the pump built enough pressue that the pump diaphram was held in a de-stroked position. I then watched for leaks from the area where the pump lever/arm comes out of the housing and no leaks were found, in addition the pump held pressure until I removed the plug that was in the outlet.
Are there are any other ways to verify if this pump is leaking?
I'm leaning towards the injection pump shaft seal, Is there any way to verify if this seal/s is leaking without removing the pump, if not what kind of test can be performed on the bench to see if the seal/s are leaking?
