630 backfiring
CFWelles
11-11-2005 03:33:25
I am looking at a 630 that is backfiring at low unloaded speeds. Is this likely an exhaust valve sticking or leaking? Tractor apparently runs well under load. Would appreciate some comments. I imagine that the head needs to come off this whatever the cause. Comments?
DP
11-11-2005 06:40:02
 Re: 630 backfiring in reply to CFWelles, 11-11-2005 03:33:25
Before you spend much time and money, try replacing the condenser. Mine used to go through a couple of them a year, and the propane 630 would also need one once in a while. They would get to where they backfire every now and then, and I found that to be the fix. Good luck in figuring yours out. Don
BushogPapa
11-11-2005 05:51:25
If the compression is good, A good remedy for sticking valves is to : Drop the elbow off just in front of the carburetor and.. With the engine running at fairly well warmed up, have an pump oilcan full of engine oil (or ATF) handy... Run at at least 1/2 throttle and pump oil into first one side of the carb, and then the other..as fast as it will take it and still keep firing on that cylinder....do each side of the carb.. this will eliminate sticking valves...AND kill every bug within a 1/4 Mile, too..!!! DON'T do this inside a building...!!!! There WILL be a huge cloud of smoke..!! I would check the plug wires and distributor cap. Look for carbon tracking inside the cap, or moisture..
Ron..
CFWelles
11-11-2005 07:19:48
 Re: 630 backfiring in reply to BushogPapa, 11-11-2005 05:51:25
Thanks fellows. That's what I need: a good list of possible causes and rememdies. Appreciate it. Take it that you don't necessarily see it as a tear down issue because it is running well at higher rpms. Compression check will be done first thing if I end up taking the plunge with this one.
buickanddeere
11-11-2005 10:26:09
 Re: 630 backfiring in reply to CFWelles, 11-11-2005 07:19:48
It could still be back firing at higher rpms but they can't be heard. A carb that is out of calibration will backfire.
720 gas
11-11-2005 17:00:28
 Re: 630 backfiring in reply to buickanddeere, 11-11-2005 10:26:09
Be sure to take a good look at the intake/exhaust
manifold. Some external I/E manifold cracks don't cause immediate trouble because they don't extend into the intake runners. Cracks eventually
extend into the intake and cause an engine to run lean and backfire, sometimes like a 12 gauge. Thirty years ago,(approx) I temporarily fixed a 49 A with red silicone. It held for several months, then let go like somebody set off a hand grenade. Its amazing I wasn't injured or busy putting out a fire. Fix it before it damages you or your tractor.
Mel
Johnbob
11-11-2005 16:57:27
Sounds like the points are set too close and sticking part time.Let us know what you find.
CFWelles
11-11-2005 20:23:22
 Re: 630 backfiring in reply to Johnbob, 11-11-2005 16:57:27
Thanks again for other posts. I am going to look at this tractor this weekend. It has much to offer, but was told of this negative by the owner over the phone. The other quirks he mentionsed: pto not stopping and occasional inability to get it in gear when going from side to side of the quadrant, are familiar to me. Since I only have gained experience on a 730D ES at this point, this gas engine problem is a new issue. Concerned me enough to ask for input from you fellows. If I aquire the tractor, I will post a followup on the cause. Would have never thought of some of these potential causes and that is part of what makes this forum so valuable.
