1935 A JD Redhead Oil gauge
wirtdeere
11-10-2005 18:19:28
I have a 35 A with a Redhead oil gauge which was before they used dial indicators. It dosen't work. Do I repair it through the main case, or the governor housing? How do you maintain correct timing for the mag if you remove the governor housing?
Maark
11-11-2005 10:52:41
 Re: 1935 A JD Redhead Oil gauge in reply to wirtdeere, 11-10-2005 18:19:28
Your Red Head oil guage is servicable through the crankcase. Remove the crankcase cover, below the red head is an oil line, remove it then use a 13/16" wrench I think to remove the fitting the oil line goes to. The red head rod and spring will then come down and out. Probably just need cleaned up on a wire brush.
wirtdeere
11-12-2005 18:08:55
 Re: 1935 A JD Redhead Oil gauge in reply to Maark, 11-11-2005 10:52:41
Thanks for the information--I've talked to dealers, but to no avail--exactly the info I needed!
dab
11-11-2005 08:55:54
You can do it thru the govener housing, Did it work before? You might be able to "lube" it up real good and CAREFULLY with a soft hammer get it to free up. Your gears on the govener should have a timing mark but if not use a paint marker and put one there before you tear into it.
