JD-H REMOVING CRANK
11-10-1999 07:44:21
DO I HAVE TO REMOVE BOTH BEARING COVERS TO GET THE CRANK OUT. IF SO DO YOU NEED A PULLER TO GET THE CLUTCH OFF. RIGHT NOW ITS SITTING WITH THE FLYWHEEL SIDE BEARING COVER OFF BUT CRANK IS HANGING UP ON SOMTHING ON THE CLUTCH SIDE! THANKS,BARRY
Dick Cumiskey
11-10-1999 08:29:00
 Re: JD-H REMOVING CRANK in reply to [email protected], 11-10-1999 07:44:21
Barry - Yes, you have to remove both the clutch assembly and both bearing covers to remove the crank from your model H. I built a puller for removing the clutch plate from the cam shaft as the commercial ones I tried just did not have the pulling power. I used a piece of 2"X2"X 1/4" steel tube, bored it for bolts, then just cranked down on the center pivot bolt until the clutch came free. The one I worked on was really tight.
