rear wheel creaking
russ lante
11-10-2005 07:04:16
I have a 1958 John Deere 520 that I use to mow and move round bales etc. Recently while moving round bales I noticed a definite creaking noise in the left rear wheel. It appears to have a very subtle wobble if you watch the rim rotate. The creak gets a bit more noticeable as weight is added or as a sharp turn is made. Im not sure exactly where the creak comes from but my best guess is the rim. This summer i replaced a tube in the tire and had to dismount and remount the wheel. My question is does this sound like it can be fixed by taking it off and remounting it or is the rim bent? Anyone heard this or have a guess or advice on how to proceed? Thanks for your help.
russ lante
11-23-2005 06:11:10
 Re: rear wheel creaking in reply to russ lante, 11-10-2005 07:04:16
Nancy,
I"m no expert on these tractors. I imagine once you jack the wheel off the ground and try turning the adjusting nut that should move the wheel that something else is binding. Penetrating oil and tapping with a hammer or using an impact wrench may break it free. short of thatI suggest post a note on the regular list and see if they have any suggestions . sorry--russ--
Nancy Howell
11-22-2005 09:14:06
 1955 JD 70 rear wheel - how to get them to move i in reply to russ lante, 11-10-2005 07:04:16
We have a 1955 JD 70. We want to move the rear wheels in enough that the tractor will fit on our eqmt. trailer. We removed the large bolts and tried to use the two that are supposed to push the wedges out. We also tried to turn the screw that turns the cog in the hub to move the tire, but nothing would budge. We soaked everything with a penetrating lubricant and wd40, but no luck. Is there some "trick" to this?
russ lante
11-14-2005 06:02:25
thanks for all the advice.
you guys were right.
i snugged up the bolts, went twice around the wheel one nut will need to be replaced (it slips in the socket) even with that one noticeably about an 1/8th of an inch shy of the others. the creaking vanished thanks again
Don L C
11-10-2005 18:21:16
I think these other guys are right on.....i would only add ,loosen each nut about 3/4 turn,then cross tighten the lug nuts....use a torque wrench if you can.....
Bobl1958
11-10-2005 13:30:17
Almost a sure bet that you have loose lugs. Make sure they are even.
hHOWARD
11-10-2005 13:20:06
Russ if your rim is out of round you did not get the wedges drawn up even. Take a good block of wood and lay along tire spin the wheel and draw wedges up evenly checking the space between the block and tirer like you whould do on a big truck tire. I think The rim is walking on the wedge and that is your noise.
Tx Jim
11-10-2005 07:34:51
Russ,rear wheel creaking can be either the hub bolts or rim wedge bolts loose. Tx Jim
russ lante
11-10-2005 08:43:02
 Re: rear wheel creaking in reply to Tx Jim, 11-10-2005 07:34:51
Jim, thanks for the advice I'll see if they are loose....--russ--
