4020hydraulic leak
Fudpucker
11-09-2005 19:19:03
Hello everyone,
I have a two 1967 4020Ds (syncro ranges) and both of them have developed hydraulic leaks. I cannot seem to find were the fluid is coming from. It is dripping on the ground under the differential just about where the right axle would enter the housing and it is a pretty good amount. It leaks while running and will also leave a puddle when not running. I am hoping this isn't going to be a teardown job but I'm not to optomisic. Any thoughts would be appreciated. Thanks.
DRB
jdat jared
11-10-2005 20:38:50
 Re: 4020hydraulic leak in reply to Fudpucker, 11-09-2005 19:19:03
i think that two pop is right. it sounds like a load shaft to me. look under the rear end, where the transmission case meets with the casting where the three point arms meet. if it is leaking from there, it is the load shaft.
with the age of the machines in question, i would get the load shaft along with the bushings and the seals. you may also want to replace the bushings in the three outer casting too.
Jared
Fern(Mi)
11-10-2005 11:44:28
May not help but we"ve had trouble with hydralic lines rusting out and leacking fluid from under the deck. May be another place to start.
Fernan
Gary Brady
11-10-2005 06:26:23
I had the same problem.I removed the cover over hydraulic fill tank. The high pressure line to my lift cylinder was very loose. There is a plastic return line behind the right battery and that line could be damged or just loose.
Best regards,
Gary Brady
twopop
11-09-2005 19:37:16
sounds like the load control shaft seals are leaking.get new seals from boling-machine.com they also supply new shafts.you need a repair manual but its an easy job to replace.
msb
11-10-2005 22:30:07
 Re: 4020hydraulic leak in reply to twopop, 11-09-2005 19:37:16
twopop is probably right ,but the 4020s are notorious for battery acid fumes eating the brake lines behind the batteries.Check them also.
Fudpucker
11-11-2005 11:33:12
 Re: 4020hydraulic leak in reply to msb, 11-10-2005 22:30:07
Thanks for the advice. As soon as I get a day off from my regular job I"ll check all of these suggestions. Thanks again.
Fudpucker
