jd rods
john mlady
11-09-2005 18:22:05
Hi, can anyone help me out, I have a 1941 or 42 jd (B) not sure of the year some books say 41 others say 42,S#124717 but one rod has babit and the other has inserts, the one with the babit is in not so good shape I would like to replace it with the insert type. I was wondering if anyone could tell me what rod & bearing I will need to do this, the crank shaft jornal looks to be in very good shape yet. THANKS, JOHN
Mike M
11-09-2005 19:22:57
 Re: jd rods in reply to john mlady , 11-09-2005 18:22:05
You are really better off if you could find some good used babbit ones as they are more forgiving on a worn crank.
davisfarms
11-09-2005 18:45:28
one out of a 50 jd will work that is most likely what you have ,mic your crank and order bearingfrom jd place
