Bolt on clutch handle
Ivan in Mich
11-09-2005 17:50:05
Could someone tell me how the bolt that holds the clutch handle to the tractor housing comes out? Is it threaded into the housing or is it a press fit? Thanks
john in IN
11-09-2005 18:19:56
 Re: Bolt on clutch handle in reply to Ivan in Mich, 11-09-2005 17:50:05
This bolt is a press fit using a straight knurl. Be careful not to hit it with a hammer very hard, it could crack the cast iron bracket. If you can figure out a good way to press it out, that works best.
Good luck,
John
Walt in Jaxn Tn.
11-09-2005 19:19:06
 Re: Bolt on clutch handle in reply to john in IN, 11-09-2005 18:19:56
Someone on this site was selling a tool that safely removes that pin. I think I saw it about a year ago. --Walt--
Mike Aylward
11-09-2005 20:04:27
 Re: Bolt on clutch handle in reply to Walt in Jaxn Tn., 11-09-2005 19:19:06
I am the one that makes the tool for removing these pins. Let me know if I can be of service. Mike
Walt in Jaxn Tn.
11-09-2005 22:02:44
 Re: Bolt on clutch handle in reply to Mike Aylward, 11-09-2005 20:04:27
Mike, how much parts and shipping to 38305? --Walt--
Mike Aylward
11-10-2005 09:38:43
 Re: Bolt on clutch handle in reply to Walt in Jaxn Tn., 11-09-2005 22:02:44
Walt, anymore I mail these pullers in a flat rate postal package. The total cost to about anywhere in the lower 48 states is $34. You can inquire on the email and I should get the message. Mike
