Changing 4020 Water Pump
MCL
11-09-2005 14:58:40
I took the water pump off my father-in-law's early 4020 gas. There has to be a better way than I did it. I reached in from the left side, took the bolts out that hold the fan and pulley on, let the fan lay against the radiator, then took the bolts out of the water pump. Then I wiggled the pump out the left side engine opening. Getting those bolts out that hold on the fan was a bear. I still wasn't sure it would come out but it did. I wanted to take the fan shroud off but that required removing the hood to get to the top bolts. That would mean taking off the exhaust pipe, air intake, blah blah blah.
Not too familiar with these. I spend most of my time around the other green ones.
donmyeil
11-10-2005 06:23:29
 Re: Changing 4020 Water Pump in reply to MCL, 11-09-2005 14:58:40
Good advise from below however I just drop the generator and remove it from the right side.
Mike M
11-09-2005 19:29:42
I have worked on many 2 cyl. and you really will come to like the newer tractors like that 4020. Way faster to pull stuff apart on them. You really can pull that radiator out pretty fast and it's a good time to get it checked out.
G/MAN
11-09-2005 15:16:46
It doesn't take much time at all to pull the hood and lift out the radiator. Leave the muffler on and lift the hood over it, or hang the hood on the muffler. Getting the radiator out of the way makes the whole job much easier, and a guy can give it a good blowing out while it's out of the tractor. I've seen a lot of guys that will fight a job for an hour working around a part that could be removed in 10 minutes.
