AIR COMPRESSOR PROBLEM
Bud W
11-09-2005 14:52:26
I have a Delco A/C Compressor that keeps cycling on and off ( clutch kicks in and out every few seconds ). Does anyone know what might be causing this? Also the low side pressure is about 80 lbs according to my gage. Thanks
donmyeil
11-10-2005 06:27:37
 Re: AIR COMPRESSOR PROBLEM in reply to Bud W, 11-09-2005 14:52:26
If you have that much low pressure most likely its over full on freon. other things could do this such as a worn out compressor but with the recharge kits available from discount stores its to easy to just put in more gas.
jas
11-09-2005 17:24:32
If it is a newer car the radiator fan should be electric and it should be on when the a/c is on. Some had two fans, one for radiator and one for condensor/ac. Check that first.
G/MAN
11-09-2005 15:19:07
That low side pressure is WAY high. What's the high side? I'll bet it's way up there too, and it's the high-pressure switch kicking the compressor off when the pressure gets too high. What's the compressor on? Older Deeres used a superheat switch in the compressor that would ground out and blow a fuse in the compressor clutch power circuit if the pressure got too high or too low. Sounds like your system has pressure switches mounted elsewhere.
Bud W
11-09-2005 15:44:23
 Re: AIR COMPRESSOR PROBLEM in reply to G/MAN, 11-09-2005 15:19:07
Its actually on my car but since I have had so much luck getting good data on my A I thought it wouldn't hurt to ask this question.
What would cause the compressor to build high pressure?
Thanks
G/MAN
11-10-2005 07:35:56
 Re: AIR COMPRESSOR PROBLEM in reply to Bud W, 11-09-2005 15:44:23
A restriction in high side of the system or a plugged condensor. Or the system could simply be overcharged. Has the system been converted to R-134a? If so, the refrigerant charge should only be about 80% of what the R-12 system was. If the high-side pressure is high because of a plugged condensor, the low-side pressure is usually driven up as well.
Bud W
11-10-2005 10:06:06
 Re: AIR COMPRESSOR PROBLEM in reply to G/MAN, 11-10-2005 07:35:56
Turns out the problem was that the system was empty of 134A . The high side port was leaking badly.
Thanks for the help
Bud
G/MAN
11-10-2005 13:19:05
 Re: AIR COMPRESSOR PROBLEM in reply to Bud W, 11-10-2005 10:06:06
The system was empty and you had 80 psi on the low side? Never heard of that before. Low side should have been in or near a vacuum.
Bud W
11-10-2005 16:00:15
 Re: AIR COMPRESSOR PROBLEM in reply to G/MAN, 11-10-2005 13:19:05
Doesn't make sense to me either but I can't argue with success. He fixed the leak and recharged the system and all is well
Lee B
11-11-2005 04:55:33
 Re: AIR COMPRESSOR PROBLEM in reply to Bud W, 11-10-2005 16:00:15
The system was cycling on it's protection circuit, if there is no pressure the compressor will NOT turn on at all. 80 was enough to turn it on, pressure dropped past the safe point (20?)and the compressor was shut off only to repeat the cycle. You should have been able to see the lower 'on' pressure (and reported that instead) if your gauge was fast enough, perhaps you didn't have the valve open far enough?
G/MAN
11-11-2005 07:27:00
 Re: AIR COMPRESSOR PROBLEM in reply to Lee B, 11-11-2005 04:55:33
80 psi on the low side with the compressor off is way more than you'd see with a charge in the system, and you'd never get close to that with an empty system. A low-pressure side safety switch usually won't kick out until the pressure is under 5 psi, as you can have a low-side pressure that low at ambient temps. Good pressures in a R-1345a system at say 80 degrees ambient would probably be around 10 on the low side and 175 or so on the high side.
Lee B
11-11-2005 23:13:25
 Re: AIR COMPRESSOR PROBLEM in reply to G/MAN, 11-11-2005 07:27:00
Air in the system could account for the pressure measured, does that count as empty? And is that my fault? 80 psi is not unreasonable for a warm system that is off. Low side on a working system is closer to 30 psi and 40 degrees for an evaporator temperature, gauges have a handy temperature/pressure scale right on them. In the past decade, I've not seen an evaporator temperature even close to 35 degrees, way back when they used to be around 30 and people didn't complain about it either. 10 psi might be found in an ice maker though, or any other system in need of a charge.
G/MAN
11-14-2005 07:26:56
 Re: AIR COMPRESSOR PROBLEM in reply to Lee B, 11-11-2005 23:13:25
Temps and pressures depend on the system, the charge, atmospheric conditions and the condition and cleanliness of components like the evaporator and condensor. And also airflow over them. A dirty cab air filter in a tractor will screw up your pressures big-time, even with a proper charge. 30 psi is WAY high on the low side for an ag system, unless you're at 110 ambient. And I've retrofitted several Deere tractor systems to R-134a that have had sub-40-degree air duct temps. I only service several dozen A/C systems per year, so I don't have much experience to draw from, though.
DickD
11-09-2005 15:16:09
Bud; I am not aan air compressor specialist, but I think I would start with the pressure switch that kicks the compressor in and out.
