4020 Selective Control Valve
Tom/Idaho
11-09-2005 09:39:32
1964 4020D has kind of a high pitched whine coming from the control valve. It goes away when you move the three point lever, but once the lift arms reach that point, it comes back again. Sounds like a problem with the relief valve if it has one in there. I am going to check the JDpartspage to see if there is one there. Any suggestions would be appreciated. Thanks Tom/Idaho
G/MAN
11-09-2005 13:20:22
 Re: 4020 Selective Control Valve in reply to Tom/Idaho, 11-09-2005 09:39:32
Is the noise coming from the actual selective control valve, which is under the hood in front of the firewall, or from the rockshaft housing, where the rockshaft valve is located?
HTR
11-09-2005 10:33:45
The thermal relief valve, for the selective control valve, is located on the front cover of the box. It takes a one half inch wrench to take it out. You don't have to remove the box. The valve is shim adjusted, and is a common problem. Usually if the valve is leaking the remote cylinder will creep up, and lift the implement out of the ground.
Bob
11-09-2005 10:07:05
The Deere SCV's use poppet valves, rather than spools, as many other hydraulic controls use.
They are operated by cams, and the unit must be set up using a jig and a dial indicator to get the valves set correctly.
If the valve settings are "off", or the valve(s) or seat(s) are damaged, or have metal particles jammed in them, problems like your's can occur.
msb
11-09-2005 18:52:52
 Re: 4020 Selective Control Valve in reply to Bob, 11-09-2005 10:07:05
To add to what Bob has said; An internal hydraulic leak usually causes the hydraulic oil to get hot.Does your oil seem to get hot?
