GEAR SHIFT ON 1952 B
AMO
11-08-2005 18:11:45
THE NEIGHBOR JUST GOT A 1952 B , IT IS IN FAIR SHAPE, WILL NOT RUN AND HE IS TRYING TO SEE IF THE ENGINE IS STUCK BUT THE TRANSMISSION SHIFT LEVER WILL ONLY GO INTO 6HT GEAR. ANY SUGGESTIONS WILL BE APPRECIATED.
DickD
11-09-2005 15:33:40
 Re: GEAR SHIFT ON 1952 B in reply to AMO, 11-08-2005 18:11:45
Amo; The best way we have found to free up a stuck engine is to fill the cylinders with diesel fuel and let the tractor sit for 2 or 3 weeks before applying any pressure to break it loose. Then slip a pipe through a chain faastened through the holes in the flywheel, and apply the pressure. Normally they will break loose with a little coaxing. As to the shifter, I would pull the top cover off and see if I could find the problem
Mike M
11-09-2005 07:05:22
Don't tow it around to free it up ! Take off the flywheel cover and chain a bar to the flywheel or use a comealong wraped around it to the drawbar frame. Towing around will only break tranny parts.
