2010 Oil Pan is HOT - water temp normal
Robert Cash Mol
11-08-2005 16:03:48
Have a 2010 John Deere Diesel that the shop replaced the rod bearings and the crank wasn't bad...they cleaned it up with emory cloth too. Tractor runs fine on water temp. and it will read 190 like when we brush hogged with it for a hour last weekend. BUT the oil pan is super HOT - they swear it could be close to 500 degrees or something when they ran it last. Do you think another bearing went out or any other suggestions I can give them. FYI - we last month had the oil pump rebuilt at the Deere dealer since it couldn't be ordered anymore. Oil pressure is now a pretty good 45 lbs. and before it was 5 lbs. Thanks.
G/MAN
11-09-2005 13:31:35
 Re: 2010 Oil Pan is HOT - water temp normal in reply to Robert Cash Moline, 11-08-2005 16:03:48
Your engine oil temp should be roughly the same as your coolant temp, depending on the engine. I seriously doubt that oil is getting anywhere near 500 degrees, as no oil would take the temperature for any length of time. If you're concerned, install an oil temp gauge or shoot the pan with a infrared thermometer after running the engine for a while under load.
buickanddeere
11-09-2005 13:15:18
500F would have the oil drips and smears on the outside of the pan flash into vapour imediately. Some may even burn. If water splashed on the pan doesn't boil than don't worry about it. Lube oil should run about 180F. That helps keep the oil cleaner. Much over 225-240F and mineral oil begins to break down rapidly.
Heat Houser
11-08-2005 18:25:04
How hot is hot? You can hold your hand on 120 F, it is not comfortable and you want to jerk it away but you can keep it there. Anything above 120, and you will jerk your hand away. I would suggest that you measure the oil pan temp with a infared heat gun. I bet the temp is less that you think.
Robert Cash Moline
11-18-2005 15:28:12
 Re: 2010 Oil Pan is HOT - water temp normal in reply to Heat Houser, 11-08-2005 18:25:04
Thanks for all your help. We did have find a friend with a infrared heat gun and the oil pan temp. after the tractor was running good and long was 275.6 degrees according to the shop. So it sounds like that is still hotter than it should be? It wasn't 500 degress but they said it still seemed like it was. Any other suggestions and do you think it is to hot then at that and will do long term damage? thanks! I appreciate the help so far...
