730 D 3pt not raising
big iron
11-08-2005 10:15:55
Does anyone have any idea why the three piont arms on my 730 don't raise when the lever is moved? The hyd pump is on and the fluid level is full. I don't have a hyd cylinder to make sure the tractor hyd are functioning. It looks like the hyd box on the rear had been replaced once upon a time. Does the hyd system need to be bled? Any help would be appreciated.
Glen in TX
11-08-2005 22:45:12
 Re: 730 D 3pt not raising in reply to big iron, 11-08-2005 10:15:55
JD SM2011 shop manual hydraulics covers it and a I&T manual will also. Could be leaks or a sheared woodruff key on pump? Stuck or improperly set or leaking relief or check valves?
big iron
11-09-2005 13:07:28
 Re: 730 D 3pt not raising in reply to Glen in TX, 11-08-2005 22:45:12
I was afraid of that...nothing simple anymore!
Thanks for the info Glen.
GPULLER
11-10-2005 07:37:53
 Re: 730 D 3pt not raising in reply to big iron, 11-09-2005 13:07:28
Nothings simple anymore??? That tractor is 46 years old, EVERYTHING was simple back then! Looks like you better get a trip lift 4-14's, if you don't have one already.
Kevin L.
11-11-2005 10:48:11
 Re: 730 D 3pt not raising in reply to GPULLER, 11-10-2005 07:37:53
if it has the single or double hyd. box with no cylinder plug in, would the tractor not load up for a short time at about 8 or 9 hundred RPM til it tripped if you moved the level to the full forward or reverse position to tell you if the hyd relief and pressure was working and hopeing the cylinder connection and hyd. lines were in good shape.
