Grampaw used kerosene in winter. ???
CLK n Cypress
11-08-2005 10:00:45
Recall grampaw used a amount of kerosene with water to prevent freezing during the winter. Now it seems unsafe, plus it wouldn't stay mixed up with no water pump to keep it stirred up. What A/freeze recipe do you guys recomend for me to use on a B with no water pump? By the way thanks for all the advice in the past & future on my first B.
Clay.
JGC
11-09-2005 16:18:55
 Re: Grampaw used kerosene in winter. ??? in reply to CLK n Cypress, 11-08-2005 10:00:45
I heard that farmers used to drain the rad and fill it with pure distillate (like kerosene) for the winter.
As others have said, make sure you mix the anti-freeze and water very thoroghly in a bucket before you pour it into the rad. The thermosythom does not mix the two if they are poured in separately. A mechanic I know says that he has heard of 2 cylinder blocks & heads cracking because the two did not mix!
ET
11-08-2005 11:39:31
I have an old textbook that has mix ratios for kerosene as anti freeze and some othere things to. The one I found interesting is honey and water. Be sure to mix the antifreeze and water before you put it in the tractor, with a thermosiphon system there is no waterpump to mix it and force it to curculate.
Kurt_JDB
11-08-2005 14:32:03
 Re: Grampaw used kerosene in winter. ??? in reply to ET, 11-08-2005 11:39:31
Most definitely premix the antifreeze/water. I did not do this on my B, and the temp quickly rose to over 210 in about five. min. The difference in density prevents the thermosyphon from begining circulation until the mix is much hotter, and the two parts do not readily mix.
I would also use a 50/50 mix of water/antifreeze.
Kurt
F-I-T
11-08-2005 13:48:39
"The one I found interesting is honey and water."
Not sure that would work as well in the A's and G's as it would in the "Bees".....
Sorry. it was there, and I couldn't help myself....
CLK n Cypress
11-08-2005 13:11:23
Heard of several things and seen a few too but this is the first on the honey mix. Whats the ratio of water to honey?
Clay.
PeterE
11-08-2005 14:23:13
 Re: Grampaw used kerosene in winter. ??? in reply to CLK n Cypress, 11-08-2005 13:11:23
Anything that dissolves in water will affect the freezing point. Sugar-based solutions (sugar, molasses, honey) were often used as early anti-freeze compounds.
Sugar water is pretty rough on the cooling system components, so these home-blends weren't used after gylcol based antifreeze hit the market in 1927.
old
11-08-2005 10:44:15
50/50 mix of any good antifreeze.
b1cow
11-08-2005 15:33:37
 Re: Grampaw used kerosene in winter. ??? in reply to old, 11-08-2005 10:44:15
Folks did use straight Kero. in the winter. Once the vapors boil off and you don't explode during that process, you're good to go! It's hard on your hoses though. I drain my A in the winter. The 50--50 mix is the best route. Stir well first before cooking.
