2 45 loader Questions
Kris A NC
11-08-2005 04:31:35
First of all I have a 45 loader I am wanting to get new hoses for. However my 45 loader came with one hose per side attached at the back of the cylinder. Then they plugged into the side of the power-trol. The manual shows there should be a hose from the front and the back of each cylinder. What is the front hose for and do I need this? Second question is on using a pioneer coupler. The manual also says to use a coupler one size bigger then your hoses. If I am using 1/2" hoses do I need to get a 3/4" coupler or would a 1/2" be sufficient? Thanks for the responces in advance. I always appreciate any feedback
Kris A NC
Mike M
11-08-2005 05:41:33
 Re: 2 45 loader Questions in reply to Kris A NC, 11-08-2005 04:31:35
I used 1/2" hose and pioneer couplers on mine with no problems. The number of hoses depends on which model of tractor you are mounting it on. If on like an A,B,50,60,70 you need two hoses as the front of the cylinders act as extra reservior capacity.On say a 520,530,620,630,720,730 they hold enough oil you only need the 1 set of hoses. These are only really single acting cylinders.
55 50
11-08-2005 13:38:41
 Re: 2 45 loader Questions in reply to Mike M, 11-08-2005 05:41:33
Why would anyone want to hook up only one set of hoses on the later tractors? Seems downward pressure would be useful as long as it's available.
Mike M
11-09-2005 07:08:38
 Re: 2 45 loader Questions in reply to 55 50, 11-08-2005 13:38:41
Like I said before,those cylinders are only single acting the packings won't really hold pressure the other way.
Kris A NC
11-08-2005 10:38:15
Mike M you have been very helpful, but could you tell me where you plugged your other line into? The manual shows below the power-trol unit. Is that correct or could you go through the side with the second connection as well? thanks again. If you had pictures that would help greatly! Thanks
Kris A NC
Kris A NC
11-08-2005 06:06:12
the tractor this loader was mounted on when I bought it was a late styled A and only had the one connection. Just curious. Its not a problem to hook both up just curious about it. Thanks for the info. Helped out a lot!!
Kris A NC
Mike M
11-08-2005 06:32:39
 Re: 2 45 loader Questions in reply to Kris A NC, 11-08-2005 06:06:12
On that late A I would think you would run out of oil and not be able to lift to full height without the two hose set up. Unless someone plumbed in an extra reservior ?
Kris A NC
11-08-2005 06:34:45
 Re: 2 45 loader Questions in reply to Mike M, 11-08-2005 06:32:39
It didn"t appear there was, but I appreciate your response. I got the answers I need. Thanks very much! Hopefully I can have it up and running here soon.
Kris A NC
