If the hydraulic pump goes "in stroke" during cranking, and starts building hydraulic pressure, starting is made more difficult. You can manually de-stroke the pump, to see if this aids starting, and, if so, install an "electric destroking kit". The 2 terminals on the alternator are labeled "1", which is "switched ecxite", and "2", which is "voltage sense". The # "1" wire gets hooked to the ignition switch through a #194 lamp ("idiot light") OR a diode (such as a 1N5008). The lamp will drop the current feedback to a level too low to cause "after-run", or the diode will eliminate current feedback altogether. Also, it is possible you have the tractor's original ballast resistor still in the circuit, feeding a coil that does not require a ballast resistor? I would set this up as original, with a ballast resistor ahead of a coil designed for one, and be sure the "starting bypass" circuit from the "R" terminal on the starter solenoid to the ignition switch side of the coil is intact. This bypasses the ballast resistor, for a hotter spark during cranking.
