Jim, I have been here before but have to think it through again each time as I didnt save my previous posting. This is based only on theory and I havent looked at any diagrams, but if you understand that, you ought to be able to figure out how to wire it. The switch has 2 input voltage THROWS, one (NC) for the NOT depressed reading wired to the Gen or VR's GEN terminal, while the other (NO) requires it be depressed to get voltage from the VR's BAT terminal. The Common Pole is then what feeds voltage (either from the VR's BAT terminal when depressed, or from the VR's GEN terminal otherwise) to the Fuel Gauge while the Gauges output wires to the tank sender. The switch is a 3 terminal (SPDT) Single Pole Double Throw switch. Its spring loaded Normally Closed in the GEN position and Normally Open (requires it be pushed for closure) for the BAT position. The Common Pole is what feeds the gauge and it receives voltage EITHER from one NC Throw (the Gen terminal on the Generator or VR for a reading when shes running and NOT pushed) or the other NO Throw, the BAT terminal on the VR, for when shes pushed down. The way it works is that when the Genny is working it supplies voltage to the gauge via the gennys output, but when shes setting you dont wanna run down the battery, so to check fuel you must depress the switch so the gauge gets battery power via the VR's BAT terminal. With the button NOT depressed, theres continuity between its Common Pole (to gauge) and the Throw to the Genny or VR's GEN terminal. Then when its depressed, theres continuity from the Common Pole (to gauge) to the VR's BAT terminal. THEREFORE a simple continuity tester will help identify which switch terminal wires to where, the Gauge and BAT and GEN terminals. Clear as mud????? ?/ John T
