4010 PTO Problem
Star Ranch
11-07-2005 14:18:48
My 4010 is in the shop for the third time with the PTO out because the two pins sheared. This time I know it is because the back bolts got loose. What can I tell my mechanic to do to fix this problem for good? All I need is the 540 rpm.
lonzo
11-11-2005 22:02:20
 Re: 4010 PTO Problem in reply to Star Ranch, 11-07-2005 14:18:48
after everthing is back together have your mechanic add a pipe spacer undre the shifter rod washer and snap ring so that it is always in 540, if you need a 1000 just remove the snap ring and washer and pipe spacer, and do what the other guys are saying about pins and bolts in the stub shaft
Tx Jim
11-08-2005 04:15:51
Star Ranch,if one doesn't need 1000 rpm pto my cure works and it's alot cheaper than needing a 2nd or 3rd split. Tx Jim
gwece
11-07-2005 18:39:35
For the 1000 rpm gear removal do a search on "4010 pto pins" and look at Tx Jim 01-27-05 post.
gwece
11-07-2005 17:54:34
After the second time this happened to me, I had the PTO shaft holes tapped out to the next size up and had the stub shaft drilled to match. Also, I think I have seen posts on this site about disabling the 1000 rpm capablility internally so you don't have the bent pin problem if the stub shaft comes loose. You might do a search to check this out.
DaveH IA
11-07-2005 17:10:35
If you get the bolts from a late model 4020 that hold the clutch cover to the flywheel(they have a nylon insert lock) you will have the right length to use a lock washer and even a little red lock-tite---but you still need to check them and never force the shaft--turn it by hand till it seats down completly and hold it there while you tighten the bolts--make sure the shaft is not bent (check run out)--check U-joints on your drive shafts--
