3 Pointer Question
Weekender
11-07-2005 11:08:56
Stupid question but my 3 pointer on my JD 2355 is not level; there appears to be an adjustment device on the right rear arm as you approach the tractor from the rear. There is no handle, just a small shaft with a hole in it - tried to clamp a vice grip on it to turn it but wouldn't budge. Any suggestions?
F-I-T
11-07-2005 12:08:35
 Re: 3 Pointer Question in reply to Weekender, 11-07-2005 11:08:56
WK:
Generally, one of the two lift assemblies is adjustable, either through a turnbuckle, or via a crank adjuster. Sounds like yours is missing the crank. Also, pretty typical of a three point that has not moved in a while, that adjuster is stuck. Look it over and see where you can oil or heat or both. Once you have it apart, I'd use some good quality water-proof grease, or some Nev-r-Seez (graphite impregnated grease). It should work fine then.
Sorry I don't have a picture of what you have, but you can go to JDPARTS and see diagrams of your particular model.
Frank
