1010 John Deere
RWALKER
11-07-2005 09:56:00
I have a friend that has a 1010 special (Gas), about a 1961. He has a problem with loss of power when the tractor has been in use for a while and gets hot. He uses it in his garden primarly. When it is first started it will pull a harrow or bushog with no problem but after 15 - 20 Minutes it gets very weak. Probably needs an overhaul. Have not been able to find an overhaul kit listed for this tractor nor have I been able to determine if it has sleeves and if they are replacable. Would appreciate any info.
Thanks
RWALKER
Doug Anderson
11-10-2005 18:16:26
 Re: 1010 John Deere in reply to RWALKER, 11-07-2005 09:56:00
Coil
buickanddeere
11-08-2005 01:59:54
Check the cheap simple stuff 1st. If the engine has reasonable power and begins to fail after 20 minutes. You are going to rebuid an ok engine and still have to fail due to some faulty accessory.
ralph oregon
11-07-2005 10:58:31
they have a plate that goes across all 4 cyl. with liners connected. ralph
Johnbob
11-07-2005 17:47:14
 Re: 1010 John Deere in reply to ralph oregon, 11-07-2005 10:58:31
The kit to overhaul will cost about 1,600.00
I would check the gas cap it may not be vented.
