AR 277647
Randy Losey
11-06-2005 19:41:46
I have a styled AR with a govnenor that is not working, it will not rev up under a load and you have to manual assist it at which time it drops back. Can anyone tell me how these work and what I may do to correct the problem. I would also like to know a Napa part number for oil filter and how much does it hold.
Tony W
11-07-2005 16:22:33
 Re: AR 277647 in reply to Randy Losey, 11-06-2005 19:41:46
Had the same problem with my 37 and found that the flat spring on the govenor and the throttle was broken and needed to be replaced. Worked great after that. JD dealers have it in stock.
Hope this helps Best of luck
Glen in TX
11-06-2005 21:41:28
8 quarts, fill to where running out test cock and then close and add a extra quart. Check again after running. Oil filter AR26350 or AA3680R or napa# FIL 1242. Could be governor problems?? or carb or fuel or intake or valve or other problems. Have you tried setting the carb and opening load needle more? I&T JD-4 shop manual, PC675 parts catalog & OMR2004 operators manual.
Randy Losey
11-08-2005 20:34:09
 Re: AR 277647 in reply to Glen in TX, 11-06-2005 21:41:28
It was fine before I had the carb rebuilt???
Glen in TX
11-08-2005 21:23:12
 Re: AR 277647 in reply to Randy Losey, 11-08-2005 20:34:09
Try setting the needles again and if that doesn't work talk to who rebuilt it about redoing it. Make sure you have a good flow of clean fuel to the carb. Some more crud probably came loose in one of the hidden passageways and needs to be cleaned out. It needs to be soaked and bead blasted and all the brass plugs removed cleaning out the passageways with wire and numbered drills by hand to run right.
